I'm trying o identify a wire terminal, I've been through all the usual data sheets for Molex, Panduit etc and can't find it. Wondered if anyone could put a name or reference number to it.
The terminal I'm looking for is a crimped female pin terminal that's used on domestic and small commercial refrigeration compressors. It's approx 5mm wide, 3.5mm high and 7mm deep excluding the wire crimp part. I've attached a vague sketch looking from the back of the terminal. Any suggestions appreciated and thanks in advance.
