today's fault | on ElectriciansForums
Discuss today's fault in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
RCD tripped. narrowed down to SWA feeding hot tub. never seen SWA connected like this before. armour not earthed anywhere. was supposedly professionally installed. the pic shows a 30mA plug-in power breaker RCD, the type you'd fit to a lawn mower cable!
[ElectriciansForums.net] today's fault
disconnected both ends and IR tested SWA . L/E 0.04 Meg. N/E 0.23 Meg. 40m of SWA, partly buried. half way down had been repaired? with choc block and tape.
so , it's quote for new SWA, glands, ad. box, correct installation. what i'm not happy with is that it's fed from the garage sub-main which is in turn fed from the house RCD in a split board, so a fault will take out all in the house except lighting. now, i've not done any work on hot tubs, but my thinking is to feed the garage sub. from the non protected side of the house ( it's fed in SWA ) and then fit RCBO in the sub. to cover the garage socket ( just a fridge/freezer) and a 13A FCU to feed the SWA to the hot tub. anyone see a flaw in this? worked out the VD at 13A to be 9.5V using 40m of 2.5mm SWA.
Not had much to do with hot tubs neither. Not many people up here have even herd of a bath, let alone a hot tub. But it sounds ok to me. Just be carefull with the frdge/freezer on the rcbo, if it trips and they dont know until a few days later, all the beer and food for the bbq will be ruined.
P.s. You have big thumbs!!!!!!!
Jay
hmm. as the cables to the fridge/freezer socket are surface.i could leave on MCB and label as dedicated socket, then a RCD FCU for the hot tub. might have to fit a RCD socket for tool use though.
With my Sherlock Holmes hat on,I would deduce you are left handed
"Where are the nicotine stains on the right hand Watson"
wrong on both counts, sherlock. i'm right handed, and don't suffer from nicotine stains, only on my facial hair.
and i use that thumbnail for tightening roofing bolts.
it's not that big. you know how these wide angle lenses distort--- make guys look like they got huge noses? well it's the same.
I dont need any help from wide angle lenses to make my nose look big. My 9 year old says it looks like the slope at Xcape in Castleford. I do however need a wide angle lense for something else.........or so the wife tells me...lol
Jay
Reply to today's fault in the UK Electrical Forum area at ElectriciansForums.net
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
wouldn't surprise me if we adopt this sooner or later...
