MCB triops every 20, 30 mins. | on ElectriciansForums
Discuss MCB triops every 20, 30 mins. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Midlands
HI all,
Got a problem here
about 12 lights on a circuit, IR tests out ok, but the MCB trips about every 15 or 30 mins.
cant for the life of me find the bloody fault, taken everything apart but nothing,, i switch on all lights nothing for 15 mins then trips, i turn off all light nothing, then suddenly trips, how the hell can i test something that's not there, its really doing my head in, Board changed, down stairs neutral borrowed on the landing light so them two circuits on the same trip, no shaver, no fans
one thing i haven't try'd is Changing the LE lamps, but it still trips when all lights are off,, OMG its doing my head in
any ideas going forward
thanks
Grandf
no its an extension and i was temporarily putting ends in the old board when it started, so ive changed the board now, and changed the MCB for a 10 amp from 6, there has been a chippy working alot there, but cant see where he could have nailed a cable, thats what im thinking of now, but its just that it happens every 30 mins or so, not every 5 mins, or every 2 mins. so bloody strange.
pendants and chrome bathroom lights, had all the switches off, most of the switches is where the feeds are, i assume its a dead short and not an earth fault as it doesnt trip the RCD, whats bugging me most is the time on it, the 30mins+, i could live with something getting HOT then tripping but then it wouldnt take that long to trip again if i turned it back on has its hot already if you know what i mean,
i have about 8 new lights in the extension and about 7 old light from the old part of the house. going back on thursday as they are away. so on one will be in the house.
one thing that has happened is a loft extension, so joists have been layed on top of the loft rafters so thats my next cosentration point, but still the timing of the bloody think bugs me, the bloody fault is either there or not.
thanks for the reply' s guys
Grand
one thing guys, this circuit has been live for weeks with no problems
In which case where have other trades been doing work, not looking to point fingers but there could be a correlation between the work and your "fault".
Have fun and do let us know what you find. Faults like this are a pain to locate!
bet you find one of these nasties.
[ElectriciansForums.net] MCB triops every 20, 30 mins.
Have you put all the lights on then clip an amp probe at the CB ? also if stuck swap the supplies over with another circuit and see what happens
ie check what load the circuit is drawing plus if ok and you swap it with another CB then see if that trips as well.
If you dont have an amp probe check Screwfluxout as they have a budget one for about ÂŁ10 bucks
  • [ElectriciansForums.net] MCB triops every 20, 30 mins.
Reply to MCB triops every 20, 30 mins. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
