MCB triops every 20, 30 mins. | Page 2 | on ElectriciansForums
Discuss MCB triops every 20, 30 mins. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Probs wont help you too much but i had the same fault on a med centre the other week tripping randomly anything from 5 mins to 5 hours. Bunch Tested circuit, clear. Replaced mcb, Same. Dissconnected all lights tested again, clear. Eventually what i fouind it to be was when it had been installed at least 15 years ago in galv pipe and singles they used ceramic connector in a through box then into the fitting in flex. and it was a line single trapped between ceramic block and through box and over the years with heat etc it had blown apart and then obv tracking across at random times and tripping! Took me 9 hours to find this bugger! Had a well deserved pint that night!
ok guys, thanks for your help and reply's,, it was a steel beam put down for the loft bedroom, it was trapping the cable, had to take the landing ceiling down to find it, two days labour x2 men down, but glad ive found it as its a weight off my mind.
Cheers
Grand
Reply to MCB triops every 20, 30 mins. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
