Hi every one i was just looking for a bit of help i have been given some home work from college that i am not sure on, We have just started learning about 3 phase so not very good at it yet but i have been given home work i have to draw a circuit diagram and a wiring diagram for a balanced 3 phase motor going into a 3 phase isolator (i dont have to draw the motor i just have to start from the isolator) which then will go into a 3 phase board i understand that but the thing is i have to go from the 3 phase board to 2 seperate single phase consumer units (like a domestic consumer unit) the problem i have got is if it is a balanced 3 phase motor supply there will not be a neutral connector going into the 3 phase isolator or board so when i go to wiring the single phase consumer unit will i still have to put a neutral in as the neutral will just end up stopping in the single phase board and wont go anty where else as the 3 phase is balance i know that in a single phase circuit you need the neutral as the return path i just wasnt sure if it needed it when fed from a balanced 3 phase motor
any help to clarify this or even a link to a good web page would help thank you
