Homework 3 phase to single phase | Page 2 | on ElectriciansForums
Discuss Homework 3 phase to single phase in the UK Electrical Forum area at ElectriciansForums.net
Baker1988
Kingston Upon Hull
Hi every one i was just looking for a bit of help i have been given some home work from college that i am not sure on, We have just started learning about 3 phase so not very good at it yet but i have been given home work i have to draw a circuit diagram and a wiring diagram for a balanced 3 phase motor going into a 3 phase isolator (i dont have to draw the motor i just have to start from the isolator) which then will go into a 3 phase board i understand that but the thing is i have to go from the 3 phase board to 2 seperate single phase consumer units (like a domestic consumer unit) the problem i have got is if it is a balanced 3 phase motor supply there will not be a neutral connector going into the 3 phase isolator or board so when i go to wiring the single phase consumer unit will i still have to put a neutral in as the neutral will just end up stopping in the single phase board and wont go anty where else as the 3 phase is balance i know that in a single phase circuit you need the neutral as the return path i just wasnt sure if it needed it when fed from a balanced 3 phase motor
any help to clarify this or even a link to a good web page would help thank you
Hi every one sorry for the late reply been at work, I am sorry for not making sence this is actually practical work in the work shop but i have to do the wiring/circuit diagram as home work.
this is what i am starting with it is already put up.
[ElectriciansForums.net] Homework 3 phase to single phase
and i have to make a materials list and circuit/wiring diagram for what i have to do
this is a rough drawing of what the finished product should be
[ElectriciansForums.net] Homework 3 phase to single phase[ElectriciansForums.net] Homework 3 phase to single phase
i have to wire from the 100 amp isolator below the 3 phase board and my tutor said just assume the board is supplyed by a 3 phase balanced motor so i will not need a neutral from the isolator to the board.
i do not have to wire a motor or even draw a motor i just have to assume a 3 phase balanced motor is connectec into the main 100 amp isolator.
and as i said the only thing i am not sure about is when i wire from the 3 phase board to the single phase board will i have to put a neutral wire in as there is no neutral to the main 3 phase board
no the supply is not on the left the supply is under the 3 phase board, the isolator on the left is just a swa cable from the 3 phase board to a isolator, i have been told by my tutor that i should not put in a neutral for the 3 phase supply as i should assume it is a 3 phase balanced motor so seen as i am not putting a neutral from the motor to the 3 phase board do i still put a neutral in the single phase board?
OK, wherever the supply is, you need to bring the N from there to the 3P board.
You're right, you don't need the N for the motor cct.
ok thank you thats what i needed to know thank you
- - - Updated - - -
You can't be supplying the 3ph DB from the motor.
i am just going by what my tutor said he said its supplyed by a 3 phase balanced motor
Reply to Homework 3 phase to single phase in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Three phase or single phase it is not correct.
