Ant infestation | on ElectriciansForums
Discuss Ant infestation in the UK Electrical Forum area at ElectriciansForums.net
VoltzElectrical
Nearly Esteemed
[ElectriciansForums.net] Ant infestation[ElectriciansForums.net] Ant infestation[ElectriciansForums.net] Ant infestation
Went to a streetlighting column today and thought I'd found the reason for the fault, but alas no, there is still a L-N short on the cable underground somewhere. Interesting pictures though. Mad what you find!
Need to clear it out better than that as fault may be under the terminal cover.
Sorry mate, I should have been clearer. I stopped taking photos and started fault finding which included clearing the cutout right out to eliminate any possible shortage between conductors. This sign light is fed off another which in turn is fed off a street lighting column via a fuse in a carrier. Voltage at fuse carrier but blows when fuse inserted. Tested on low ohms and getting 1 ohms between live and neutral. Will let office know they will send a digging team to expose the joints, cut out and re terminate probably, but I might not be on that as depends who gets the ticket.
Reply to Ant infestation in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
Im not as clever as you guys. I would be doing what somw others have said, I would be leaving certain items switched off for a period of time...
