Discuss new supply been put today to new building ,NO EARTH in the UK Electrical Forum area at ElectriciansForums.net
scary though isn`t it...There are times when this forum needs an insane questions section then a filter built in to exclude them from appearing in the new posts lists
evening my obnoxious friend...lol..i can smell the epic fail of this thread from all the way over the other side of the interwebz.
you guys should get some air freshener.
lol.
its nearly as bad as watching my girlfriends 16 year old son cutting an unsliced loaf of bread earlier but holding the cut slice!!!!
HANG ON....this doesn't make sense. The DNO don't do meters, they just do heads, yes? And the meter fitter won't normally just put a tails in and energise them without knowledge of what's on the other side of them, nor (in my experience) will they fit a meter without fitting the tails in as they like to seal it all up...... so, there must have been a set of tails left there by the OP ready for the meter fitter (along with some sort of assurance of isolation downstream). Where was the installers earthing conductor???
If you don't bring them a cable then they can't fit it!!!!!!!!!!!!!!
GEORDIE SPARK its off at the moment and its locked.
Reply to new supply been put today to new building ,NO EARTH in the UK Electrical Forum area at ElectriciansForums.net
