M
momac1985
Hey folks just looking for some info here..
Im after changing my element for my immersion as it kept triping the RCD..
I installed a backer bt7 7" Rod, I wired it the following,
(1)Live to The Element
(2)from the other side if the element I connected it to the L on the immersion
(3)Neutral to the N on the immersion
(4)Earth to earthing point
The problem is it keeps tripping the RCD..I disconnected all cables from the element and I got 240 across L-N & L-E
Its at number 2 above is where my problem is, when I connect from one side of the element to the L on the immersion it trips..if I wired everything else bar connecting that cable it wouldn't trip the RCD..
Any ideas??????
Any ideas??????
