A
amckay
I've started subbing on a site on Monday (the site has been active since July) and today I had to earth containment trays, putting copper bars over joints etc. Anyway its a 10 story building and it has a riser for cabling. However the trays in the riser are not continuous its just a 1.5m section thrown against the wall with around a 18 inch gap in between floors. So I'm linking them together by crimping 16mm2 and using 1 inch long bolts (they supplied them). The way i have bolted them is with the threaded shaft protruding the top of the tray where the cable lies. My supervisor rekons niceic will "fail" it as the cable sheeth could tear against it during installation.
Personally instead of swapping the bolts around, I rekon a bit of heat shrink will do the trick
Am I wrong?
Bearing in mind this is the first time I've done commercial as I've mainly done pat and domestics
Am I wrong?
