tray work | Page 2 | on ElectriciansForums
Discuss tray work in the UK Electrical Forum area at ElectriciansForums.net
A
amckay
I've started subbing on a site on Monday (the site has been active since July) and today I had to earth containment trays, putting copper bars over joints etc. Anyway its a 10 story building and it has a riser for cabling. However the trays in the riser are not continuous its just a 1.5m section thrown against the wall with around a 18 inch gap in between floors. So I'm linking them together by crimping 16mm2 and using 1 inch long bolts (they supplied them). The way i have bolted them is with the threaded shaft protruding the top of the tray where the cable lies. My supervisor rekons niceic will "fail" it as the cable sheeth could tear against it during installation.
Personally instead of swapping the bolts around, I rekon a bit of heat shrink will do the trick
Am I wrong?
Bearing in mind this is the first time I've done commercial as I've mainly done pat and domestics
I've started subbing on a site on Monday (the site has been active since July) and today I had to earth containment trays, putting copper bars over joints etc. Anyway its a 10 story building and it has a riser for cabling. However the trays in the riser are not continuous its just a 1.5m section thrown against the wall with around a 18 inch gap in between floors. So I'm linking them together by crimping 16mm2 and using 1 inch long bolts (they supplied them). The way i have bolted them is with the threaded shaft protruding the top of the tray where the cable lies. My supervisor rekons niceic will "fail" it as the cable sheeth could tear against it during installation. I don't know about the NIC-EIC failing it but I would.
Personally instead of swapping the bolts around, I rekon a bit of heat shrink will do the trick It won't
Am I wrong? Yes
Just reverse the bolts, save all the hastle.
I'm blaming the crap internet at this hotel.
have a word with the manager.
[ElectriciansForums.net] tray work
They were domed headed. I installed them that way as mentioned in op the bolts were 1 inch long and the gap was 1/2 - 3/4inch. So it was impossible for me to get my hands round the back to tighten up.
Screw a nut right up to the head of the spouting bolt, put bolt in vice, cut the 10/15mm off the bolt and when you're finished take the nut back off the bolt, this will reform the thread.
If you think i'm telling you how to suck eggs i'm sorry, you're only an apprentice i don't know your level
I'm not an apprentice iv just not completed nvq yet but have core quals. I've been round today and replaced all nuts with smaller ones
use the holes on the side of the tray instead or get shorter bolts?? If you've realised that you can't get your hand in then surely bolting it to the side is the better idea as how the hell are you going to get a roofing bolt tight enough without using a dirty great big flat head to hold it in place, **** poor mechanical connection there fella
You're right. I dropped loads of bolox when I was serving my time though.
I'm we all did trev, best way to learn lol
light gauge doesnt have holes in the sides
keep your crap roofers and ill stick to my pozi head roofers :)
you can keep your flimsy tray fella, don't use it, come to think of it I've only ever used it at college and yeah I really do like pozi headed roofers too especially when they come with proper nuts too but most firms are too tight to splash the cash for those
Specially when you get a clout round the head when you do make a mistake. Kind of drives the lesson home properly :)
ahhhhhhh the good old days :stooge_curly: had to stop myself from doing it to the last apprentice cause apparently it's not character building anymore it's bullying.................
Reply to tray work in the UK Electrical Forum area at ElectriciansForums.net
