1.0mm against 1.5mm T&E lighting circuit | Page 2 | on ElectriciansForums
Discuss 1.0mm against 1.5mm T&E lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
A
Aggravated
Hi, to one and all, my first posting, as the title suggests, what do people think about the differences between the cables, I know that the circuits should be carefully designed and considered, insulation in lofts/walls, length of runs etc, but to my mind it should be 1.5mm. The cable manufacturers don't make single 1.0mm
Your comments are invited
Wonder how many will admit to being cheapskates.
No, but I'll happily admit to being lazy. I can't be bothered with buying/stocking two sizes for lighting, so all I stock/use is 1.5mm. It's not to say there's any issue with using 1.0mm, or that I wouldn't use it, simply that I don't.
I don't have an issue with terminating 1.5mm as some have said, if anything I find the slightly stiffer cable easier to work with as it 'sits' better.
Unfortunately I'm only doing domestic at the moment so have no reason to stock 1.5
1mm will more than easily take the load of each floor of lights (few years time I wouldn't expect a entire house's lighting load to be more than 100w), might even drop down to 3amp MCBs....just because :lol:
Reply to 1.0mm against 1.5mm T&E lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
Recommended Sponsor News
Hi everyone,
