1.5mm circuit 1mm switched drops | on ElectriciansForums
Discuss 1.5mm circuit 1mm switched drops in the Australia area at ElectriciansForums.net
B
bugsy
Went to a job today ( domestic ) checking through the installation ( which has recently been rewired ) I noticed that the lighting was 1.5mm but the switch drops were 1mm anyone seen this before?
The switch drop will only take the load of the lights it is switching so probably a good cost saver if the jobs a bit tight.
Obviously it's a hypothetical situation that would probably never arise in most domestic properties but if the 1.5 was used to it's maximum surely the heat that would conduct through the copper would be too much for the 1mm.
exactly :) i got pulled for using the old tubes on my first NIC inspection. He went into the loft just to inspect if we'd used them. had a right go at me - still passed though.
Still save the old grommets though
1mm^2 Tri-rated cable??, second thoughts, dont think that would be cost effective
It's a mis-conception that Tri-rated has a higher current rating; the cable actually to conforms to three different standards. These standards are:
1. BS6231 ~ (UK)
2. UL Subject 758 Appliance Wiring Materials (AWM) ~ (USA)
3. Canadian Standards Association (CSA) approved.
Reply to 1.5mm circuit 1mm switched drops in the Australia area at ElectriciansForums.net
Ouch. Danger notice to customer in my book.
