1.5mm circuit 1mm switched drops | Page 2 | on ElectriciansForums
Discuss 1.5mm circuit 1mm switched drops in the Australia area at ElectriciansForums.net
B
bugsy
Went to a job today ( domestic ) checking through the installation ( which has recently been rewired ) I noticed that the lighting was 1.5mm but the switch drops were 1mm anyone seen this before?
Think because he didn't earth the tubes or put end grommets on the tops of the drops sorry if I got that wrong. It is suppose to be earthed metalic conduit regardless of new or old technically.
The circuit would therefore be considered as wired in 1mm (the "weakest" point of the circuit) and current carrying capacity would be calculated on that basis.
The installer would have effectively wasted metres of 1.5mm on the lighting runs.
my lecturer on my course said he always used 1mm singles for the switched drops.
He said it was part cost, part helps to tell the cable apart..!
in fact my house is wired that way come to think of it..
Agreed. Seems a stupid idea to me, why not just wire it all in 1.0mm?
It's a mis-conception that Tri-rated has a higher current rating; the cable actually to conforms to three different standards. These standards are:
1. BS6231 ~ (UK)
2. UL Subject 758 Appliance Wiring Materials (AWM) ~ (USA)
3. Canadian Standards Association (CSA) approved.
i knew why it was called tri rated, but had also been told it had a higher current rating,
we live and learn.
Reply to 1.5mm circuit 1mm switched drops in the Australia area at ElectriciansForums.net
Ouch. Danger notice to customer in my book.
Com is short for Common, sometime just C, or in the case of your old switch , L1 It is the side of the switch that is always connected… the link...
