10.5kw shower works on a 32 amp T1 MCB (via a 6mm t/e cable) | Page 3 | on ElectriciansForums
Discuss 10.5kw shower works on a 32 amp T1 MCB (via a 6mm t/e cable) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
nah. he's right. quadratics are 4 legged fish.
Have fun! I've not used them since college.
More to the point I don't want to use them. Although if I'm really bored one night I may have a go at doing a spreadsheet.
if i have got to work something out using multiple equations ill make a spreadsheet now.
at some point ill make a google doc up with all the common ones e.g. cable calcs etc (will be interesting to see how much i remember from my A level IT course)
Reply to 10.5kw shower works on a 32 amp T1 MCB (via a 6mm t/e cable) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
