10 amp inline connectors | on ElectriciansForums
Discuss 10 amp inline connectors in the UK Electrical Forum area at ElectriciansForums.net
Wirral
I have a range cooker with 1 oven that is electric and runs on a 13amp plug instead of the usual hard wired cooker connection. The original instructions (now mislaid) said that it should be plugged into a 13amp outlet, not an extension. I cannot move the cooker to see the plate to verify the power consumption.The lead is 12 inches short of the 13amp outlet so I want to extend the lead using an inline connector. I can only find 10amp 3 pin inline connectors. Is this the max that is made and would this be safe to use with an appliance with a 13 amp plug.
I would imadgine the advice about not using an extention lead is because there are a lot of them about that arent suitable for 13A. Either because they are on a reel, or a 4way could end up becoming overloaded, or some are just badly made with cheap materials.
As mentioned already, if you use a piece of 1.5mm flex, properly terminated in to decent connectors (duraplug or permaplug should be suitable), you wont have any issues.
Alternatively, can the socket be moved closer?
I would replace the entire flex with one of the correct length, rather than joining the existing one. Using a flex type that matches the existing one of course.
beat me 2it. replace whole lead.
Reply to 10 amp inline connectors in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
