10 Bedroom house rewire. Ring or radial? | Page 3 | on ElectriciansForums
Discuss 10 Bedroom house rewire. Ring or radial? in the UK Electrical Forum area at ElectriciansForums.net
Moaz
Bolton
Guys, I'm wiring a ten bedroom house which has 4 floors. Correct me if I'm wrong, but as fat as I know, new regs says to keep each room on a radial. So shall I keep each room on a radial or have a few rings on each floor after calculating the maximum demand??
Anyway Moaz wire it how you like. You know the property and it's layout.
Just be aware of you cable lengths and do your calcs...and you may need to do 4mm radials if the property is that big..
R1+Rn (which you can get from Onsite guide)multipled by the rating of fuse you want to use multipled by the correction factor of 1.2 (70c)
Simple job done.
Simple job done.
not if there are seperate CU's on each floor, depends how big the "floor" is though, it might be 10 small box rooms or david camerons house
Your right it could be very small :) but the OP is the one who's been there
I think Moaz said it was large, he didn't say if the DB on each floor was at the middle or the end of the house. So who knows how long the radial could end up being.
Why a hot potato?
Because they need to be licenced / registered with the local authorities, inspected and subject to more stringent tests etc than a normal domestic property.
A single room in my patch (in a scruffy area) can easily be "worth" ÂŁ500 per month, so convert the lounge and dining room and hey presto a 3 bed house is now a 5 bed HMO - so ÂŁ2500 per month or ÂŁ30,000 per year .....
Then there are cash payments and loss of tax revenues
I could go on
I could go on
we had a landlord try convert their 3 bed house to a hmo, they didnt split the ring upstairs where all the rooms are though lol, still it will be something for the tenants to fight over when the bill comes in
What new reg it that? what reg are you referring to that gives you that impression? however, if that is the/your design there is nothing wrong with it it is in my view a bit OTT unless there is more to this house than a family house.
Reply to 10 Bedroom house rewire. Ring or radial? in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
