100 amp 3 way connector? | on ElectriciansForums
Discuss 100 amp 3 way connector? in the Electrical Tools and Products area at ElectriciansForums.net
I’m sure there’s normal connector block rated at 100A, but wouldn’t trust it.
Normal “Henley” blocks are the only way I think.
You used to get dual blocks with a 5way live and neutral in the same plastic box… but maybe not available now.
Does it have to be inside the switch fuse, or is there room outside?
Thanks all... That rs pro link does what I ask but can't see a way to fix it so will be floating in the enclosure, at least a line tap has fix holes so can be screwed to the back, which is kinda desirable at this level
Reply to 100 amp 3 way connector? in the Electrical Tools and Products area at ElectriciansForums.net
Your electrician shouldn't be doing anything to the cutout, that is the property of the electricity supplier and they make the connections to it...
davesparks
All good thanks, still trying to retire but still finding myself busy as ever. Hope you're well.
