100A DP isolator switch | on ElectriciansForums
Discuss 100A DP isolator switch in the Australia area at ElectriciansForums.net
R
rtonne10
Hi There,
Looking for a bit of advice. I am in the middle of altering the wiring in my cousins house as he is having the meter moved. I've not mounted the CU as not 100% sure where the meter is going to be mounted. The problem I have is the REC are not supplying and isolator so can someone tell me if I fit a 100A dp isolator and leave tails connected to the supply side will the REC connect the other end into the meter. I can't make it on the day they are coming.
Rtonne10
Reply to 100A DP isolator switch in the Australia area at ElectriciansForums.net
Thank you, that's a really helpful post, nice & clearly stated and helps me clear up a lot of confusion on this matter.
2 3 4 5
6K
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
