100a jsu fuse required asap | on ElectriciansForums
Discuss 100a jsu fuse required asap in the Commercial Electrical Advice area at ElectriciansForums.net
Reply to 100a jsu fuse required asap in the Commercial Electrical Advice area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
Locally most supplies are 80A. The stated reason is that the supply agreement is for 15kVA and an 80A fuse is the nearest to this, a 60A being...
    • Informative
Good point, I was assuming an up-front RCD is for fault protection within DB, etc, and to cover for a failed RCBO for fault conditions, not as...
This is an RSS feed of thread: ADVICE for young plumber required please staffs/midlands Content of the thread: hi all, posting on behalf of my...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
