Here is my thinking. First some definitions:
Total Installed Capacity - means the maximum capacity at which an Eligible
Installation could be operated for a sustained period
without causing damage to it (assuming the Eligible Low-carbon
Energy Source was available to it without
interruption), a declaration of which is submitted as part
of the processes of ROO-FIT Accreditation and MCS certified
Registration;
Declared Net Capacity - means the maximum capacity at which the installation can
be operated for a sustained period without causing damage
to it (assuming the source of power used by it to generate
electricity was available to it without interruption) less the
amount of electricity that is consumed by the plant;
Eligible installation - means, on a Site, any Plant Owned by a FIT Generator
capable of producing Small-scale Low-carbon Generation
from the same type of Eligible Low-carbon Energy
Source, the Total Installed Capacity of which does not
exceed the Specified Maximum Capacity;
Small-scale Low-carbon Generation - means the use, for the generation of electricity, of any
Plant:
(a) which, in generating electricity, relies wholly or
mainly on an Eligible Low-carbon Energy
Source; and
(b) the Total Installed Capacity of which does not
Eligible Low-carbon Energy Source - means the following sources of energy or technology:
.............. (d) solar photovoltaic;
Plant - means any equipment, apparatus or appliance;
In abbreviated form the argument is as follows. TIC is the maximum an Eligible Installation can be operated at. An Eligible Installation means any Plant. The Plant is the inverter. The definition of Small-scale Low-carbon generation refers to the Plant as having the TIC. The solar panels are the Eligible Low-carbon energy source. It is the maximum output of the inverter, coupled to the panels, that is relevant in declaring TIC.
As I read it the DNC definition is all about ac being fed into the grid. The TIC uses identical wording and I believe it is also referring to ac power output. There may be other equipment in the plant room that draws power which reduces the TIC figure to a DNC figure. In the case of a simple low voltage inverter situation without any other equipment on the ac side then I believe the best interpretation is that DNC = TIC, less perhaps 1% for cable losses. I do not believe potential power in from the solar panels on its own is relevant to determining the TIC if it is the inverter limiting the maximum power out rather than the number/size of panels connected.
Regards
Bruce
Registration;
Plant:
Source; and
Regards
Bruce
