10v rcd backfeed? | on ElectriciansForums
Discuss 10v rcd backfeed? in the Australia area at ElectriciansForums.net
hi guys
if i test between live and neutral on a lighting circuit which is rcd protected
and the mcb is off . why do i get about 10v on my volt tester? a mate said something about backfeed from the rcd? is this true if so can you explain why?
thanks in advance
Reply to 10v rcd backfeed? in the Australia area at ElectriciansForums.net
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
