110 metre submain for 4/5 bed new build? | Page 2 | on ElectriciansForums
Discuss 110 metre submain for 4/5 bed new build? in the UK Electrical Forum area at ElectriciansForums.net
B
BillyH
What size swa would be needed for a 4/5 bed new build property submain burried direct in ground?
Sorry for the vague info, i will explain more.The supply is for a 4 or maybe a 5 bed house (100A). Allowing for a 5% vd the cable size would be 50mm.
0.94x110x100/1000 = 10.34
Am i close
close, but VD for lighting is 3%, so i'd err on the side of caution. better to install a slightly oversized cable than have to dig out and replace an undersised one.
i got 70mm based on 80A demand.
5.6V drop.
I just got an email from the guy. This is the only info i have. I know nothing about whats on site whatsoever so can't comment further .It reads as follows;
I need to put in 5 supplies. One each for the 3 units - these will all be say 3 bed, and no electric heating or showers. They each have a cable run of 75 metres.
One run needs to go to the house - this will be about 110metres, and it will be a 4/5bed house.
The other one needs to go to the sewage treatment plant, which is again about 120 metres, but only needs to run a 200 Watt pump.
Everything single phase.
Why would this be preferable to getting the board in to give new supplies?
you need a site meeting mate and deisgn it correctly, also submains are cheaper than paying the dno
we all get a brain fart now and then. best to be sure before doing than make a cock -up
- - - Updated - - -
This will help you out in times of rustyness.
Cable-Mate
or AEI cable finder on line, it's free.
Reply to 110 metre submain for 4/5 bed new build? in the UK Electrical Forum area at ElectriciansForums.net
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
Good luck with your project and I’m starting in 2 weeks to install the same thing as you.
