110v site lamps at 240v domestic | on ElectriciansForums
Discuss 110v site lamps at 240v domestic in the Domestic Electrician Forum area at ElectriciansForums.net
High Peak
Hello,
I have bought some site lighting with 110v plugs to rig up in my shed workshop which has a 240v domestic supply. Obviously I can use a site inverter but I would like to avoid this. Is it just a case of rewiring and fitting 240v halogen bulbs? Some help would be greatly appreciated. Cheers.
The 110V GLS lamps we have in the stores last about an hour at 240V, but can only be switched on once or it will blow the second time. Light and heat output are tremendous.
Reply to 110v site lamps at 240v domestic in the Domestic Electrician Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
Hi I've nearly completed the 2357 NVQ. I'm just a bit stuck with Permits to work, Planned program of work and method statements. I work in the...
