110v sockets | on ElectriciansForums
Discuss 110v sockets in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
it depends on what test equipment you have. i had no problem testing the circuits a portsmouth navy base that are 110v
you can always do R1+R2 and then calculate
Reply to 110v sockets in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would suggest you forget this, never heard anything like it either, if the "old" motor isn't up to scratch then buy one that is
The motor is a common AC 120v 60hz motor. I've seen a hundred of them around for various things. It is attached to a single vent squirrel cage...
