116v at lights | on ElectriciansForums
Discuss 116v at lights in the Talk Electrician area at ElectriciansForums.net
DJ Electrician
Hi
This is my first post and just a little background info I completed level 2 and 3 at college (full time) and have got a job with an electrical contractor in Southampton, I dont think I'm 'properly' qualified until Ive done a couple of years out on site but I'm getting there.
Anyway, I wanted to practice testing etc at home and did earth fault loop impedance on a few of my lights, some tested fine and a few wouldn't test, I flicked the meter on to volts and it was measuring 116v (using 3 lead) so I tested between line and neutral and measured 230v but between line and earth just 60v.
What would cause something like this, I'm guessing a poor earth connection (high resistance) but not certain hence my question?
Thought I'd add to this it was the same with lamp in and out
Hi DJ, When you connect a 3 lead meter to L-E-N and the E is floating, your meter effective creates a potential divider of equal value impedances across the supply, hence the volt drop across either impedance is approximately half the supply volts and this is what you have measured, 230/2 = 115V, virtually the 116V your meter indicated.
what was your dead test, R1R2 or R2 or even your Zs
you may posibly be using the meter wrong, before we can start fault finding.
Reply to 116v at lights in the Talk Electrician area at ElectriciansForums.net
Well at about 9.30 last night I stripped the door card off and found the culprit, cable snapped and end off. So I spent another hour and managed...
    • Funny
Good point James. It would have been nice if the manual had mentioned which of the leads were being used for what though. It simply shows the LNE...
