View the thread, titled "11kVA 3 phase supply" which is posted in Electrician Talk | All Countries on Electricians Forums.
its the single phase voltage times the number of phases.
I got this formula off one of the forum pages. I didnt know if it was correct thats why i asked about it. Ive since talked to an industrial electrician who told me its the correct formula to use.
to find the 3 phase voltage from single phase you multiple the single phase voltage by the square root of 3 (1.732) not by 3.
Sorry Ian, what are you confused by??
The calc is correct the sum is 15.88A per phase.
So what you are saying that he has a single phase voltage off 400 and a 3 phase voltage of 692 that is what I am saying from your calculation.
ian it was the max current per phase i was after not the phase to phase voltage but thanks anyway.
The formula i found must be a rule of thumb or something cos it works out just about the same as the formula lenny gave.
thanks for the input.
Reply to the thread, titled "11kVA 3 phase supply" which is posted in Electrician Talk | All Countries on Electricians Forums.
