bigspark17
Im wondering what the capability of a 12/24v dc water pump would be and how far it could push/lift water. I dont particularly need a large volume of water pushed from one holding tank to the other.
The system would need to be offgrid as its in the middle of nowhere on a mountain. Water is going to be used to feed animal drinkers.
Hoping that a small dc pump would be capable to save using inverter ect.
Can you give more info to the project.
Is the pump going to be pumping water upwards, level or downwards?
If upwards then how high?
It all depends on exactly what you want the pump to do. There are literally hundreds of variations.
The Jabsco range will have something to fit the bill, and while they are not cheap, they do last for a very long time, and are easy to repair.
Here is just one example of the extensive range:
You need to know the head (e.g. in metres lift) and the flow rate (e.g. in litres per minute). It's also useful to know whether it needs to lift on the suction side (or whether water from the source can flow downwards to the pump). The two main types available are diaphragm and centrifugal, which have different pros and cons. Typical DC diaphragm water service pumps will lift around 10-12 litres per minute to 15 metres head using about 4A at 12V.
So im guessing
This is an engineering problem. Don't guess... calculate!
A vertical lift of 250 yards? I.e. the outlet is 750 feet or 229 metres above the inlet? That corresponds to a pressure of 320 PSI or 22 bar. This is the territory of positive displacement (e.g. piston) pumps, such as the pump in a pressure washer. There are multi-stage centrifugal pumps for these pressures too, but they will generally be much too large or too inefficient. You haven't stated the required flow rate, which is as important to know as the head, but we can work out how much current is needed at 12V to deliver one litre per minute:
Energy to lift 1kg of water 229 metres:
= m.g.h where g=9.81m/s²
=1.0 x 9.81 x 229
=2246J
Piston pumps can achieve high efficiencies, but this is a small pump so let's call it 50% and assume this also allows for frictional and kinetic losses.
Mechanical power input to deliver 1l/min:
=2246/(0.5 x 60)
=75W
If the motor efficiency is 75%, current needed at 12V to deliver 1l/min:
=75/(0.75 x 12)
=8.3A
If a leisure battery of say 110 Ah capacity were to give 8.3A for ten hours, the pump would raise 600 litres or 133 gallons of water on a single charge.
Is that the kind of figure you had in mind? One leisure battery-full = 2/3 of an IBC pallet tank raised? You won't easily find this kind of pump on the shelf in the caravan shop, but if you are creative...
As what @PEG has suggested. There are other ways of doing this.
Seeing that this is on a mountain, have you considered using a windmill pump? No electricity needed being high up should catch quite a bit of wind.
.....and we're off! :)
There are other methods,dependant on need and pocket depth.....water harvesting,can provide more than enough,if you are in the right location.
Swapping horse,for camels,can free up a degree of need...
OK, good point. 1hp = 746W, therefore one horse can raise:
60 x 746/75
=597 litres per hour using this pump.
1cp = 683 lm/W. Dammit, that's candle power not camel power. Need data...
=1.0 x 9.81 x 229
=2246J
=2246/(0.5 x 60)
=75W
=75/(0.75 x 12)
=8.3A
this pump can now be ran on mains voltage, would the calculation be similar.
Its about 300m run with about 60M rise.
It is to supply a holding tank fed via floatswitch to supply water for cattle and sheep, not a great flow of rate required. Just that it gets there. Thanks for your help
[automerge]1589127668[/automerge]
@Lucien Nunes
@Lucien Nunes
The problem you may have is the volt drop over 300m.
What is the motor size and breaker size?
Sorry spoon,no the pump will now be going near the bottom tank by an outbuildig which has electric in it so no problem there, the300m run 65M up was a question about the size of the pump?
do you mean that the water has to go 300m along and 65m up?
Turning into quite a different problem now we have so much more information!
I love these questions!
Oddly enough, the internet provides so many answers, but if i were in the ops position I would ask a pump manufacturer for a solution. That way, you get the experience, and if it doesn't work, you have comeback.
Whatever, do not simply rely upon ads on ebay etc, but ask real people...Jabsco, referenced earlier, will be one of many who can sort you out in a very short time, and you will buy once, and enjoy for a long time.
How much water 'litres per minute' is required?
We can't size the pump without knowing this.
I've been asking that since post #6. At first the lift was given as 229m, now it's 60m, so my indication of flow rate per watt were out by nearly a factor of 4. But on the plus side, with mains now available, 60m is within the capabilities of the 'very high head' class of multistage centrifugal potable water pumps. The 12V option is more practical too, with a little less than 1 litre per minute delivered per amp of motor current when using a gearmotor to drive a piston pump.
there is not a specific ltr/min required as i said it is supplying a second holding tank. I would imagine 5-10 litres a minute would be more than enough.
[automerge]1589177061[/automerge]
thanks @Lucien Nunes. Yes the head is around 60m. The 12v is no longer in the picture as there is now mains voltage available. Do you have a link to a good pump which could achieve this? What wattage pump would achieve this.
That's not really good enough. AIUI there are figures that can be used for rough sizing of water requirements for livestock - you'll need to go looking for them. The only number I can recall (from maaaaany years ago) is around 10 gallons per cow per day for a milking herd.
Then multiply the number of animals by the nominal water requirements, and that'll give you the mean water requirements you need to be able to pump in a day. THEN you can add in the lift etc to work out what type/size of piump will do it, and what it's power requirements will need to be.
Obviously the larger the buffer tank at the top, the more leeway you have if the animals have a particularly thirsty spell - but however yo do it, you don't want to be reliant on a pump that's running 24/7 to keep up.
bigspark17
wales
United Kingdom
Electrical Engineer (Qualified)
12/24v water pump capability
bigspark17,
Simon47,
