12 way Ryfield board | on ElectriciansForums
Discuss 12 way Ryfield board in the UK Electrical Forum area at ElectriciansForums.net
Reading
Hi my name is karl of sims electrical contractors. I just started a block of flats and have to install a 12 way ryfield board via a 400amp a TP/N Isolator in a riser cupboard. What size tails should I install from isolator to ryfleld board. All to be enclosed into 6-6 metal trunking
Is that 400amp per phase ?
Reply to 12 way Ryfield board in the UK Electrical Forum area at ElectriciansForums.net
No mate, it was more out of curiosity than anything else. I see plenty in the high rise blocks that we fibre up that makes me cringe. See plenty...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Recommended Sponsor News
Hi everyone,
