124 volts on earth | Page 2 | on ElectriciansForums
Discuss 124 volts on earth in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I found the circuit at fault (lighting)
I also pulled breaker for the lighting and was ok but it also took power of 3 sockets
that tells me there's some serious problem with how it's been wired.
the earth would have to be missing from near to the cu end of the circuit. what is more worrying is that by isolating lights, you are losing power to 3 sockets.
trying not to over complicate.
2 possible causes
1, Earth leakage on a class 1 appliance
2, Crosse cpc and N
the first sould be easy enough to eliminate, and the second im afrais you are going to have to trace the circuit a leg at a time investigating every outlet and junction
Sorted the sockets out but still Cant find this problem grrrrrrrrrrrrrrrrrrr agggggggghhhhhhhhhhhhhhhhhhhhhh
Also found no earth on water ooooooooo errrrrrrrrrrrrrr
Do you think some cable some place is crushed and this is y its getting the voltage ?
If its a TNCS system i think youll find that the problem is a faulty or missing neutral do some R2& Rn tests check the Ze at the board
Reply to 124 volts on earth in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
