Hello all....
I have recently been asked to put in 9 LED 230V downlights, which I have done.. all working fine. The reason was the old 12V halogens only had 2 of the 9 working and the customer said everytime she replaced a bulb they would either not work at all or only last a few days/weeks.
All connections were tight, bulbs were a reasonable quality and the voltage was not too high. However they were completely covered in insulation so I'm guessing the transformers were getting far too hot as they were very close to the 12v lights which give off a great deal of heat.
I have all the old transformers and bulbs at home and decided to test them, all bar one bulb worked fine which confused me a bit. I know very little about the thermal overload protection of a transformer but I'm guessing this was what was happening, but I have a few questions:
1. Do all (or most) 12v transformers have thermal overload protection?
2. When the temperature cools down should the transformers start working again or does the overload protection only work once and then the transformer is broken?
3. If they should start working again, as they did at home, why didn't they in the customers house? perhaps this wasn't the problem!
Thanks chaps...
Thanks chaps...
