12v heated jacket | on ElectriciansForums
Discuss 12v heated jacket in the UK Electrical Forum area at ElectriciansForums.net
J
jimmy12345
hi there i am new to the forum so any help would be much appreciated i currently own a motorbike and have made myself a heated waistcoat it is 12v 5amp i was wondering what regulatiolns there are on me making these and selling them the only thing i can find is that it falls under low risk of a shock thanks
but there could be a risk of fire and/or burns. i think you query is outside the realms of this forum. you need to make more general enquiries regarding compliance with god knows how many rules and regs.
I have made three of them and have been using them for the last 6 years. Make sure you make them out of Teflon coated stranded wire and not single core as this will break in no time.
hth
Ben
The general electrical installation regs wouldn't cover a 12V DC item that's connected to a motorcycle battery. As Tel pointed out there is a high risk of fire or damaging the vehicle's electrical system in the event of a fault so I'd pay particular attention to making them safe by using fuses etc.
I copied mine straight from a google search, I adjusted it to meet my requirements, works a treat, looks a bit Heath Robinson so I would not be in the market to sell them. I ride all year round and the jacket makes a huge difference in the winter.
Ben
yes i have put a fuse on it is built in the plug it all seems great and works fine i have used teflon coated wire and like u say looks a bit untidy.is there any regulations on this sort of product. thanks for all your feedback
I am sure just as eggs are eggs there will be a multitude of regs and hoops to jump through if you wish to sell them. I am not aware of the regs unfortunately. I also used a 12volt pulse width regulator to control the heat which I can transfer between bikes.
ben
Reply to 12v heated jacket in the UK Electrical Forum area at ElectriciansForums.net
I
Water underfloor heating and epoxy grouts Hello, I did some reading here and there, but the opinions seem to diverge at some point and I am not...
istefanov87
I
Thank you for your reply. I manage to find the issue I think, the natural and live wasn't inserted properly in one the wago Further down causing...
