12v power inverter | Page 2 | on ElectriciansForums
Discuss 12v power inverter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yeah its very important now that you have installed the inverter now you should change that wiring too.
An alternative to your 150w flood would be to use LED strips (12v). Cheap as chips from China and pretty effective - here are 3 of them in my box van.
Reply to 12v power inverter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That switch would be hard to wire as it switches different contacts with no common, you also need to make sure they are break before make...
A searh of the manual for the inverter does not return any content for "ground". I do not find any pertinent reference in the table of contents.
