12v Relay | on ElectriciansForums
Discuss 12v Relay in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Market Harborough
Hi,
I think I asked this before, but have a 12v alarm output that I want to switch a 230v load.
Can you get a din rail mounted relay or Contactor?
Standard din rail mount 8 pin relay base and a standard 8 pin relay with 12V coil.
Any wholesaler will have them, if they don't then find a proper wholesaler!
Because the relay mounted on the alarm pcb, needs to conform to selv, must be kept at alarm voltage potential.
A separate boxed relay must be used
Because the relay in mounted on the alarm pcb, and to conform to selv, must be kept at alarm voltage potential.
Yes, any idiot knows that, but the OP was specifically asking for a relay to put in a seperate enclosure. Your post suggested that a relay was unsuitable and it had to be a contactor.
Suggest read the thread again....any idiot..? why ask the question.....? A relay and a contactor are the same thing....there is no difference between the two...?
Had a hard day,Dave? ....Tazz knows his onions with this gear,and is far from being ^^^^ :bobby:
Reply to 12v Relay in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Shhh, don't tell the Chinese they want a bit of the action.
Just an heads up here, any expansion or addition to the control system of a Fire Alarm should be suitable for the job in hand and I don't mean...
Darkwood
