12v Relay | Page 4 | on ElectriciansForums
Discuss 12v Relay in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Look at the picture he's posted, the diode is already built in to the relay he has bought!
Looks to me like an LED in series with a resistor to indicate supply to coil. It'll be the wrong way round for catching the back emf. If required, it'll need one direct across the coil facing in the other direction, ie not conducting with the coil energised with +ve on pin 2.
Ok, I'll confess I didn't actually look back at the picture. I just assumed based on the number of IMO relays and contactors I have used in the past which have it fitted already.
Personally, I prefer not to use octal or 11-pin relays as interface relays as the creepage distances can be a bit marginal for electrical separation. But I'm fussy with things like that.
Which is visible in the pic. Provide your own catch diode.
Just one quick question, Im only going to be wanting to pull the line on not the neutral, so this is presumably just achieved by connecting the line on its own between pins 3 NO and 6 NO?
I'm normally quite a patient person, but I feel this thread is still going to be running next year. Daz
I don't know about anyone else here but I learned to read a basic wiring diagram and how a relay works before I got to secondary school.
And I'm only 28 now so it wasn't that long ago!
FFS it's a 2-pole relay, each pole has com, NO & NC contacts just like a 2-way light switch. Davesparks spelled this out in post #19. Choose a pole, any pole*, and use the NO and com of that pole.
but I learned ... how a relay works before I got to secondary school.
I cannot remember a time in my life when I didn't know how a relay worked. I still have My First Relay that I made when I was about 7, SPNO and a very low resistance coil to work on a 1.5V battery, it would actually pull in on just under a volt. Dad reckoned it wouldn't have enough amp-turns to be reliable - he was right, but its limited performance taught me about contact setting, hysteresis, residual gaps etc. By the time I'd moved up to Junior School that was all old hat and I was buying relays and cradles from my favourite surplus shop in the Edgware road.
*not one with overhead cables or dancers on, North, South or one from Poland.
Reply to 12v Relay in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
No issue. Just checking in case I missed something. Better safe than sorry with 230v an 3kw! Eg @Risteard warned me mount the DIN rail option and...
Shhh, don't tell the Chinese they want a bit of the action.
