I am attempting to build a garage door remote for use on my motorcycle using a small remote and a handlebar mounted momentary push button switch. What I would like to do is remove the CR2032 battery and use a stepdown converter to wire directly into the motorcycle’s 12VDC system as I’ll be putting the remote circuit board inside the headlight housing. Is this possible and, if so, is there anything I should be concerned with such as heat or anything, and what protection can or should I add?
Appreciate the help and suggestions
I dont really know what there is to disagree about.
The L78L series employ internal current limiting and thermal shutdown.
making them essentially indestructible. they can deliver up to 100 mA output current. They are intended as fixed voltage regulators in a wide range of applications including local or on-card regulation
for elimination of noise and distribution problems associated with single-point
regulation.
In addition, they can be used with power pass elements to make high-
current voltage regulators. The L78L series used as Zener diode/resistor combination
replacement, offers improvement along with lower quiescent current and lower
noise.
I am very happy to agree with all of that long list of impressive specs.
I just happen to think that, for those that are maybe less comfortable than you and I with all of that stuff a zener and a resistor makes for a simpler and overall easier implementation.
With profound apologies to the OP if I have inadvertently / incorrectly assumed their level of knowledge in this area.
At 70p each, i would go with @mainline and just use the pre made board.
resistors, diodes etc, requires a level of knowledge to get it right that not every one has.
Waxahachie, TX
United States of America
12VDC to 3.3VDC Stepdown DIY
USA Electrical Forum
Thread Tags
Tags Tags
None
FlashGordon,
James,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
