Im changing my current 13A fused spur with a new one which is spured off the kitchen ring. the fused spur is spured off a double socket. There are 2 2.5mm2 cables with 2 red and 2 black and 2 earth wires. the flex which powers the boiler has 1 blue, 1 brown and 1 earth wires. I took note of the wiring arrangements before i disconnected the old fused spur and connected the new spur exactly how the old spur was connected but its now not working.
The 2 black wires i connected to the N terminal, 2 reds to the L terminal, the flex wire i connected the blue wire to the other N terminal and the brown wire to the other L terminal and the 3 earth wires to the earthing terminal.
Is that correct or not,
thanks WAMS
thanks WAMS
