13 Amp plug on a 2.9kW oven | on ElectriciansForums
Discuss 13 Amp plug on a 2.9kW oven in the UK Electrical Forum area at ElectriciansForums.net
J
JT101
Hi Everyone
So i've installed my first kitchen and everything has gone well. I've wired in the oven based on a sparkies recommendation but I just want to check I've done things correctly and try to understand a bit more about cooker circuits.
The oven is a single NEFF fan oven 2.9kW . There are no other ovens in the kitchen, and just a gas hob. The previous kitchen that had been installed in the last few years has a dedicated cooker switch which goes back to the circuit board on it's own dedicated fuse. Next to this fuse is a shared 30A RCD which covers the oven, ground floor lighting, sockets etc. A socket is spurred off of the cooker switch and is controlled by it. It is at the back of the oven unit.
2900W / 230V = 12.6Amps. So I put some 2.5mm flex on the oven with a 13A plug, and plugged it into the spurred socket. I'm pretty sure this is what the sparkies recommended to me.
Based on this I've got a few questions I hope someone can help me with.
1) Is this safe / correct setup, and do I need to have it certified and tested by an electrician?
2) I can see that you want a fuse as close as possible to the maximum rating of an applicance, but just out of interest what could happen if you put a 12.6A cooker on a 30A fuse? For example, if there was a fault in the oven, could it get hotter and hotter and hotter and start a fire before it tripped out at 30A?
3) Both sparkies I spoke to said to use 1.5mm flex on the oven. But I thought this was only rated up to 10A? I put a 2.5mm cable on there in anycase which I believe is rated to 13.5A, but a 1.5mm would have been a lot easier to wire into the plug.
Many thanks. Looking forward to your responses
If the oven comes with a plug on it, you can just plug it in.
There are some urban myths & misunderstanding about MCB /fuse sizes. The MCB in teh consumer unit is there to protect the cable that runs from teh consumer unit to (in your case) the cooker switch.
The fuse in the plug is there to protect the cable running to the oven and may also be there to protect the cooker itself, if that is what is dictated by the manufacturer.
1.5mm cable is rated at around 18amps, in free air, which is what you've got so that's what you need.
PS You don't need it certified, you are just plugging something in!
Understood. I can change the cable for 1.5mm.
Unfortunately this is one of those situations where I'm going to get two different opinions.
So it seems i have two options. One is to do what was recommended to me by an electrician i.e. use the 13A plug.
The second, and I'm not sure if I understand this completely, is to hardwire the oven into the load side of the cooker switch, and change the MCB. The MCB is currently 32A. The electrician I asked said maximum 15A, which is not really helpful given that they seem to come in 10A and 16A, neither of which would be suitable.
Incase you're wondering, I'm happy to pay a sparky to come round and do the hard wiring, but they're telling me to put a plug on it.
Reply to 13 Amp plug on a 2.9kW oven in the UK Electrical Forum area at ElectriciansForums.net
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
First thing to say is that it's desirable to have a method of isolation for the oven somewhere near it in the kitchen, and not hidden behind a...
