13a plug locking bracket | Page 2 | on ElectriciansForums
Discuss 13a plug locking bracket in the Electrical Tools and Products area at ElectriciansForums.net
I only want it to be inconvenient to remove, not impossible
with all due respect, it's obvious that you're not an electrician, as you can spell "inconvenient" correctly. :ack2:
I fail to see the point of these "inventions",when suitable instruction or labeling should suffice.
If such a device prevented the removal and switching,of a socket outlet connected piece of equipment,then the very first line of advice,on encountering a person suspected of receiving an electric shock,will be impossible to complete.
This "victim",will in all probability,be the very type of person, either incapable or unwilling,to understand instruction or assess risk.
...Or is this the perfect time,to market my "air-bag protection" helmets? :bobby:
I've just bought a Dyson tower fan for a meeting room, and if it is easy to remove I know someone will come in and nab it for another part of the building
A quick googlesearch reveals this, or you could get a socket put in a lockable cupboard or plug it into a floorbox and put a filing cabinet over the edge, but as others say you may need to disconnect it in an emergency.
You could fit a non-standard plug and socket so it can't be plugged in anywhere else, or my favourite options are to lock the meeting room when it's not being used and/or threaten people with disciplinary action if they misappropriate the fancy fan. Maybe tell them there's CCTV in the room. Maybe even fit a dummy CCTV camera.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
or fit a dummy fan and cctv to watch the look on their faces when they try and get it working. :troll:
Reply to 13a plug locking bracket in the Electrical Tools and Products area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
Hi, Has anyone come across DIY balcony solar panels? These are solar panel kits you can buy that plug into a regular electrical wall outlet...
  • Yoult1976
  • Ireland
  • 0
  • 193
