13A socket outley (downstairs toilet) | on ElectriciansForums
Discuss 13A socket outley (downstairs toilet) in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
I'm currently in the middle of gutting the downstairs toilet. It will only have a toilet and a small cloak room sink.
I plan to have a mirror and x1 2 gang socket outlet for the misses to straighten her hair because she refuses to do in the bedroom because there is no mirror.
Is this deemed acceptable? It's not a bathroom or any other special location?
The consumer unit is on the wall behind the toilet so it makes sense to utilise one of the spare ways.
Quick thoughts on a circuit are to install a radial on a 20A mcb. 4mm t+e. Length will be amount 1 metre.
I would like a socket that's as flush as it can be against the tiles. I've seen this which looks good.
GU3220WPW - 2 Gang 13A Switched Double Socket in White Metal Flat Plate White Insert Schneider GU3220WPW - https://www.sparksdirect.co.uk/2-gang-13a-switched-double-socket-in-white-metal-flat-plate-white-insert-schneider-gu3220wpw#.WvWJPNAo9-E
Why 4mm2 Gaz?
Reply to 13A socket outley (downstairs toilet) in the UK Electrical Forum area at ElectriciansForums.net
