13amp Double Socket with plug presented at 45 degrees- do you know a supplier ?? | on ElectriciansForums
Guest viewing is limited
Discuss 13amp Double Socket with plug presented at 45 degrees- do you know a supplier ?? in the UK Electrical Forum area at ElectriciansForums.net
A
autodonace
Hi
This question was asked some years ago on this forum but the link to the supplier is no longer active.
I am looking for a Wall Mounted 13 amp double socket that could be mounted on a narrow kitchen upstand that would normally not allow the use of moulded plugs.
as i see it there are three tradional answers - use a single socket mounted sideways
- use a std double socket inverted
- use a bench 45 degree mount
yet we see kitchen pop up units and extension mounts that present the plug to the socket at 45 degrees.
i wish to mount a unit that can be included into the quartze/granite worktop.
Already talked to MK tech support and TLC
So does anyone know of a supplier with a 13 amp double socket where the plug can be entered at 45 degrees please.
You probably want something like this and a euro plate to fit it to.
[ElectriciansForums.net] 13amp Double Socket with plug presented at 45 degrees- do you know a supplier ??
or if these fit a euro plate?
Reply to 13amp Double Socket with plug presented at 45 degrees- do you know a supplier ?? in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
Email
Time zone
Last seen
