I have the advantage on you there! I kicked Mr Wetpants out of the door 40 years ago or so, and donned his hat, alongside my sparky's one. Never had to put up with one since, (except for one couple month period, that I wrote about on here recently.)Besides, beyond all of that, does away with Mr WetPants Plumber which has to be far more important.
Can't see the point of electric boilers into wet radiator systems, without any kind of thermal store, except, I suppose, if a serviceable
wet system is already present.
Could be an advantage if you have access to significantly cheaper off peak electricity, and can use the boiler to dump heat into a thermal store and/or thick slab wet UFH.
