15% Off Everything at RF Solutions! | on ElectriciansForums
Discuss 15% Off Everything at RF Solutions! in the UK Electrical Forum area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
Solutions
Staffordshire
[ElectriciansForums.net] 15% Off Everything at RF Solutions!
15% Off of Everything at RF Solutions!
CLICK HERE TO CHECKOUT THEIR PRODUCTS!
[ElectriciansForums.net] 15% Off Everything at RF Solutions![ElectriciansForums.net] 15% Off Everything at RF Solutions!
[ElectriciansForums.net] 15% Off Everything at RF Solutions![ElectriciansForums.net] 15% Off Everything at RF Solutions![ElectriciansForums.net] 15% Off Everything at RF Solutions![ElectriciansForums.net] 15% Off Everything at RF Solutions!
700 SERIES - THE 16KM REMOTE CONTROL
RF Solutions has introduced the 700 Series of remote control product solutions for Internet of Things applications. Each Din Rail mounting 725 module has two switch inputs and two changeover contacts outputs; additional input and output DIN Rail modules can be added.
Employing LoRa (Long Range) spread spectrum RF IoT technology, the 725-TRX8-16K can achieve an impressive range of up to 16km, with a 1km version also available for shorter range applications.
The company said the product is a simple to use, out of the box remote telemetry system. However, it also boasts an array of comprehensive features available to the user to enable more complex remote switching.
Additional on-board features include an automatic Watchdog signal, a LED bar graph received signal strength indicator, timed outputs, etc. It can also operate in several modes of RF operation.
Design around a ‘building block’ concept, many different system configurations can be achieved including: a simple one-to-one; or a larger system incorporating multiple modules within a many-to-many configuration and additional input/output boards. An added benefit of the system is that it can be ‘daisy chained’ if a longer range needs to be achieved.
RF Solutions believes the 700 series will be a good choice for many different applications, including industrial switching, lighting control, M2M applications and so on.
Reply to 15% Off Everything at RF Solutions! in the UK Electrical Forum area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
