Is this relay suitable for 3kw Willis Heater | on ElectriciansForums
Discuss Is this relay suitable for 3kw Willis Heater in the UK Electrical Forum area at ElectriciansForums.net
colink
Northern Ireland
Hi
My electrical background is Auto Electrics from decades ago - 230v electiics experience is very mucch DIY.
Willis type 3kw heater. Currently switched with a DPST Manual switch.
I am hopping to add a relay in parallel with the manual switch. Relay will be switched from a SONOF / eWeLink smart switch with 230v AC output.
Just double checking if there is anything I have missed regarding the spec / suitability of this DPDT relay?
I am OK with working out what coonnections to use and not use.
If any isues with this relay please sugest an alternative.
JQX-12F-2Z AC 220V Coil 30A Relay DPDT 2NO 2NC 8 Pin General Purpose High Power Relay​
https://www.amazon.co.uk/Xiatiaosan...lpcontext&ref_=fplfs&smid=A39XV54ATO7F2U&th=1
[ElectriciansForums.net] Is this relay suitable for 3kw Willis Heater
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Hi
Hi
I would use a din rail dp contactor in an enclosure.
Reply to Is this relay suitable for 3kw Willis Heater in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
