16amp radial circuit additional sockets | Page 3 | on ElectriciansForums
Discuss 16amp radial circuit additional sockets in the UK Electrical Forum area at ElectriciansForums.net
Yorkshire
Hi all
I am looking to add 2 additional 2G sockets to an existing 16amp radial circuit that has 2 1G sockets on it.
It’s a 3 story house and the consumer unit is in the Cellar. There are two rooms on the top floor and two radial circuits are feed from the one 16amp MCB with no RCB fitted.
I want to add 2 more 2G sockets in both rooms on each circuit. The cable is 2.5mm twin and earth.
My question is can I add the additional sockets to the existing raidial circuit with the 16amp MCB or should i / could i up rate the MCB to 20amp?
Effectively there is RCD protection to the consumer units and if it is 30mA then adding the additional sockets would not be a problem, 100mA would not be acceptable for a circuit modification.
However the single RCD is not a good arrangement as it does not allow circuit level separation on earth faults.
Reply to 16amp radial circuit additional sockets in the UK Electrical Forum area at ElectriciansForums.net
Why aren't you asking them?
Do you know what percentage of scheme registered electricians are registered to sign off 3rd party work? Even better would be a poll of how many...
nicebutdim
N
