17th edition | on ElectriciansForums
Discuss 17th edition in the Australia area at ElectriciansForums.net
R
rob sparky
Hi,
Im new to this website so i dont know whether this question has been asked.
Im installing electrics in a new build 2 storey extension, now im installing a ring main for the sockets and 1 lighting feed for all the lights. (Thers 9 sockets and 26 spotlights) They have a 16th edition fuseboard fitted and im unsure whether i should install RCBO's to feed new circuits as the RCD side is full or should i replace the fuseboard at an extra cost to the client.
I look forward to hearing your answers.
Am i missing something ?? Why the concern about having 26 lights on one circuit ??
If they are halogen downlights which take maximum 50w bulbs that would be 50 X 26 = 1300w
Divide that by 230v and you only have 5.65 A , thats without even applying diversity, so even a 6A rcbo can handle this ok. Please forgive me if im being stupid here.
The reason why the type of spotlight is important as it could be an inductive load - in which case your 5.65A current is then multiplied by a factor of 1.8 to find the VA. You will then end up with a current of 10.17 amps which is pushing it for a 10A rcbo. Plus such a large inductive load could cause switching problems as Hightower (?) mentioned.
I dont know why everyone is jumping to the conclusion that there are 26 spotlights switched on one switch. FYI There are 4 no different rooms with the spotlights in each with there own switch. 1 Circuit is definitely enough because they are 50W halogen lamps. I have decided to put them on a 10A because i have 3 no outside lights on the same circuit aswell.
Dazza1976 im glad you can see what im on about, so thanks for that
Reply to 17th edition in the Australia area at ElectriciansForums.net
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
