17th ref method ?? quick please | on ElectriciansForums
Discuss 17th ref method ?? quick please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
castlon11
What is the new reference methods as havent done 17th yet was 1,2,3 + 4 now ????
A= ????
B= ????
C= ????
D= ????
Thanks !!
PVC cables surface clipped - C
Armoured cables surface clipped - C
MICC cables surface clipped - C
PVC cables installed directly in an insulated wall - A
PVC cables installed in a building void - B
PVC cables in metal / plastic conduit or trunking surface mounted on a wall - B
PVC cables in metal / plastic conduit installed inside an insulated wall - A
PVC cables in metal / plastic conduit installed inside a building void - B For more detailed information see Table 4A2 p261
All in this link mate,E,F and G too:D
Appendix 4 of BS 7671 (Full Article) - Wiring Matters Autumn 2008 (373KB, PDF
Reply to 17th ref method ?? quick please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Have you notified Building Control of these works?
