18th Regulation 411.3.4 | on ElectriciansForums
Discuss 18th Regulation 411.3.4 in the UK Electrical Forum area at ElectriciansForums.net
Heswall
Afternoon all,
Have a quotation regarding garage lighting which requires alteration. It’s a set of flats with a seperate large garage area which id class as commercial hence not needing an rcd as reg Regulation 411.3.4 states only in domestic.
The head of the flats is saying it’s classed as domestic area.
Board is mcbs but unsure I’ll squeeze a RCBO. C
Can you also just cover your own alterations with RCD or does it now have to be at the origin? I’d read on this forum it’s changed
Thanks in advance
Regulation 411.3.4 has no mention of installation method anyway?!
It doesn't have to, as far as I know (Don't own a BBB) it just means all lighting circuits in a domestic property must have additional protection, regardless of installation method.
If outside of a domestic environment an you had T&E buried in a wall less than 50mm it would need the additional protection because of a different regulation.
Thats how I read it and as it’s clipped direct I’m just trying to determine if it’s a commercial area.
Is it being used for commercial purposes, is it solely occupied by businesses who pay business rates etc etc.
Or is it a bunch of domestic garages belonging to domestic properties/ intended for use in association with domestic properties?
Reply to 18th Regulation 411.3.4 in the UK Electrical Forum area at ElectriciansForums.net
