i=p/u
My drill started smoking (not an e-cig)
any of you wise men know if carbon brushes can cause this or is the windings coating breaking down.
the brushes are wore but not completely. Small springs push them in and thinking maybe not enough push onto the armature/rotor
If the brushes are long enough to make contact with the commutator then it's probably not fixable. Can you see any discolouration of the windings ie are parts of the winding marginally darker than other parts? It could also be the built-in electronics which are surprisingly complex in modern cordless tools but the problem is if it costs you half the value of a new one to fix it you're still left with an old drill that's likely to fail elsewhere at some time soon.
i=p/u
Northern Ireland
United Kingdom
18v drill
i=p/u,
Marvo,
