K
KingKenny
... But it's causing me a problem.
First time I've asked a question on here, so thanks in advance for any advice.
The problem is as follows ...
I'm working on quite an old house in Scotland - big thick walls, etc...
I have a light switch which should operate a batten light in a bedroom. The old light was removed, so previous wiring cannot be determined. the switch has two outs - A red wire (presumably live) and a black (presumably neutral). the wiring coming out of the wall has two pairs of red/black - presumably one pair from the switch and one from the mains. The batten light fitting expects two inputs, so I've wired in the two reds together and the two blacks together. The lamp works when switched on, but blows the very old 5A fuse when switched off, killing all upstairs lights, causing me to have to rewire the old 5A fuse with fuse wire (also 5A), quite time consuming.
Now, my understanding is that neutral wires shouldn't be wired into the light fitting unless they're switch live. if so, fine - but does this mean I should terminate one of the neutrals in a block and wire in both lives together?
I would have tried this earlier today, but light faded, so I had to give up for today.
I'm frustrated because I feel I should know how to achieve this, but haven't managed to.
thanks all
thanks all
